- May 1, 2002
- Tampa, Florida. USA
it happens...
nothing in life is a guarantee
jdmcnudgent said:that sucks, 3/20/02-3/31/02 are supposed to be great.
CSHawkeye81 said:man that sucks.
i think that if you do the wire trick for 1.7v you will be ok, and not running too hot, and depending on your chip, you might ve able to hit the max of 150. atleast 145 with 1.7v if not more.Bigsexy said:
Lucky you! Setting the up voltage a bit would help me, I think! But I can´t do this in my bios (like you) and I won´t do the wire trick. I´m still hoping, Asus will bring on a bios where I can set the voltage in bios beyond fsb133, too!
CSHawkeye81 said:right now its 80mhz agp and 40mhz pci
that should be fine for you, agp/pci, bignuttz was running at that with his. i dont know what mine are at right now unfortunatley, i know its up there, but if i try to underclock them on my board, i get nothing, but i know it will work on the p4t-e. i have a tv tuner card and sblive, but i opt not to use because i would rather overclock. the only things in my box right now is my 8500, and usb2.0, which does not use a pci slot. gotta love overclocking.Bigsexy said:
oh, oh - I think my cheap tv-tuner card wouldn´t do this!
And 80mhz for the graphics adapter sounds pretty (too) much to me, too!
....how do I recognize, that the cards "dislike" the bus-speed? Will they only "not work" at all or will they work to a point and then take damage?
And @jdmcnudgent: Am I right, when I say my pci @ fsb 150 would be 37.5mhz and the agp 75mhz ??
And another question - taking a look into the jumper settings of the P4T-E I´ve recognized, I could set fsb 150 with pci 30 / agp 60 - what effects will this "underclock" for the bus-speeds have??
