- Feb 5, 2016
Here is my build thread: http://www.overclockers.com/forums/showthread.php/787677-600lbs-Steel-I-Beam-Desk-Computer-Build
I decided to put the pump next to the radiators and am concerned with how much tubing there will be to get from the radiator to the block and back. Roughly 16ft worth of tubing per loop with 2 uphill sections at 3ft each. Should I add a second EKWB D5 pump to each loop on the opposite side as the first pump?
Thanks in advance.
Josh
Thanks in advance.
Josh
