- Jan 31, 2012
- Houston, TX
Get an old or small new PSU, jump the green wire and use the PSU's on/off switch
If I draw power off the computer Molex, then the watercooling setup is turned ON and Off with the computer. There's too much chance of bubbles forming which will have to shake out. I prefer my water cool box to run most of the time. I'll have a simple ON/OFF switch, but mostly it'll run 24/7.
200 watts is just under 17 amps. So maybe 18-20 amps has about the right amount of overhead for the near future.
Thanks, Big C.
Does anyone else want to stoop so low as to offer this lowly one some of their infinite wisdom?
BO
Concerning:
"The Impact of Tubing Size"
http://www.overclockers.com/forums/showthread.php?t=515368
FYI: There is a terrific Sticky in the Water cooling forum created by conumdrum with some really great links. But the one on tubing size seems to be missing all the pictures. And the pictures seem to be where all the charts were located. Without it, all you're left with is a lot of discussion - but little of the actual data. Its probable the charts were removed from some external site.
BO
The final CPU temperatures work out to be:
6.35mm quick fit = 34.21C
8mm barbed = 34.08C
8mm quick fit = 33.91C
9.6mm barbed = 33.89C
9.6mm quick fit = 33.80C
11.1mm barbed = 33.79C
12.7mm barbed = 33.77C
Yep, guess you missed it. It was posted in 2007. Pictures were on some pic storage place, this one was: http://www.employees.org/~slf/curves/pumps/tubings.png Possibly where Cathar worked back then.
You can maybe find other links that help explain it, I did a google search for watercooling tubing size comparison, found some other links that may help.
We can only do so much to help you. And it's not my problem.
