- Feb 5, 2016
Crap that would suck if it's under the ihs... I'll reach out to silicon lottery and see what they say. They were the ones who did the delid and applied the liquid metal.2.5 gpm is well past the point of diminshing returns (~1.5 gpm)...you can slow those pumps down, really.
As far as differences between cores, thats dramatic... but not sure a nornal repaste will help... maybe the issue is under the ihs...you can try a normal repaste....
Load was 100% in cinebench and blender.First... that was under what kind of load? Some stress test type things, right (where the load is the same)? No throttling?
They are likely going to ask you to to reapply your paste before they do anything. I would wait to reach out until you know if that solved it or not.
That is too perfect of a circle of Tim. It does not look like to much paste but maybe not enough pressure on the block.
The monoblock has a round section that is raised (or lowered I guess) that sits on the CPU. That's why it's so perfect looking.
Sounds good. I too am confused by the small surface area. I'll look into other monoblock that fit better.i would return that monoblock personally. im amazed that it leaves such a big portion of the ihs uncovered. with an 18 core cpu you need to have complete coverage! i would either go with a mono block that actually covers the entire ihs or just go with a high quality cpu block. you really shouldnt need to do much if any modifications to your copper tubing from the looks of your current config.
tbh thought i was looking at an aio not a monoblock from those pictures.
p.s. what mb are you running?
Thanks for the info. What do you mean by the concave?That is one gnarly setup you got there.
I'm gonna admit, my heart sank when I first heard a delidded 7980XE (lol) and those temps didn't help the situation at all. That is one beauty of a chip you got there and as everyone's said, take your time and dial this right for the longevity of the chip.
Just make sure you have the INs and OUTs on the monoblock set and that there isn't too much of a concave going on. You might want to return that block but tbh, I would grab another block and test it with that before you return that mono.
Ohhh got it. Sorry for some reason I was thinking about the fittings (I'm exhausted right now).Concave... just as defined. He is asking to check if the surface of that block is flat... use a razor blade or something known pretty straight and see.
