- May 8, 2011
- Darlington, South Carolina
Extreme voltage will either instantly kill depending on the quality of the silicon, or over time will degrade the CPUs electrical pathways leading to premature CPU failure.
The cooler you can run it however the longer it is going to last.
Most of those that plan and intend to run high voltage also plan on sacrificing the CPU for high overclock numbers, that's not an area entered into blindly or uninformed, but those run voltages way past 1.45v.
That's the entire reason we overclockers run the coolest cooling solution we can afford to run, as the cooler you keep the CPU the lower voltage is required for the same degree of overclock.
Actually in the past Silicon Lottery was claiming their delidded pre-binned offerings were using around 1.40+ voltage to reach the claimed clock rate advertised for the CPU they were selling.
So maybe that voltage isn't that big a deal after all.
Personally I would never recommend 1.45v but it's not going to kill the CPU instantly unless the CPU was on it's last legs anyway, and all this dramatic hooplah is unwarranted.
