I have read numerous reviews that agree with this.
http://www.tipidpc.com/viewtopic.php?tid=67101&page=1
You don't have to change AS5 every three months....I'm using the IC Diamond and it's holding up quite well. Still waiting to see if I need to replace it with the same frequency as the AS5 (every 3months).
ive been using arctic silver 5 for a long time and it seems to work great, ive never had a problem and i swear by it. i wouldnt use anything else until something new comes out that works better
Any silver thermal grease is conductive, so be sure you clean evrything off including what you get on your fingers. if it makes contact with anything you'll be SOL.
You got that one confused, Arctic Silver 5 is not conductive at all, it's slightly capacitive my friend
Congrats on the greens MuddocktorI use Ceramique almost exclusively now, since I misplaced my tube of AS5. Basically I see little, if any difference in performance between the 2 and the Ceramique is much cheaper, gram for gram.
SilverSinkSam said:Basically I see little, if any difference in performance between the 2 and the Ceramique is much cheaper, gram for gram.
i misplaced my AS5
