- Jan 10, 2012
I use an asrock extreme 9 Z97 board.
a bit ago I got A Sammy 960 evo NVMe drive, gen 3x4.
got it in and the os migrated over and boy is it fast.
I decided to reinstall my second gpu and to my great unhappiness the rig suddenly will not boot, so I pop into bios to have a look around and find my Sammy boot drive missing from boot order, I see both graphics cards and even my m.2 sata drive, UH,OH
shut it down, pull the second card and it boots right up.
grab my manual to check where the second card goes and it says slot pcie4, right where I had put it so I shut down again and reinstall the gpu back in slot pcie4 and swap power cables from one gpu to the other, put it all back together and try to boot up again, it's still a no go, so I boot to bios and the 960 sammy is not shown anywhere but both gpu's show up just fine, uh, oh
pull it back out again, grab the manual and check where else the second card can go, pcie slot 5 looks to be the next place, but, it's not going there, that's where all the front panel connecters are and the card will not slide all the way into the slot. where to next?
pcie slot 2, right where it will cut all the air off to the card in slot 1 but, hey let's try it shall we.
yes, it boots right up and both cards show up in gpu-z with card 1 running at 87c under heaven benchmark.........
so what I can't find anywhere from asrock is that pcie4 is turned off when you install an NVMe drive in the ultra m.2 connecter........
I love my hobby!!!!!!!!!
