- Jul 15, 2010
A friend of mine pulled this out of an old dell workstation, and we thought we'd get some use out of it. The 200mm fan that came in the top of my 600t had awful airflow and an annoying whine, so it got booted, I hooked up the two 120mm's that were on my heatsink and in the rear exhaust to the top, and put this guy in the back. I'm getting *way* better airflow both from the top and the the rear, between 5 and 15 degrees C cooler temperatures, and it may be quieter than the old setup was (It's hard to tell, the dorms are always pretty loud).
It's one of the ~200 cfm Deltas, I have it at 800rpm most of the time but it gets up to 4000 according to the ASUS fan utility
Anyway, on to the pictures:
First trying it out. It took some "alternative" wiring to get it hooked up. The dell used some proprietary connector (kinda like a mini pci-e connector)
Realized it was pulling mostly air from the case instead of through the heatsink so I rigged up a shroud. It made about a 5 degree difference
Just for reference this is what I was using before
