cozmo_d said:Theres gota be a way to know weather or not im getting a C ???
Is there a certain code on the chip too look for like amd's ?
or a part#
I want the C
mtb856 said:The IC7-G MaxII is exactly the same as the IC7-G, but the Max II has a newer BIOS I believe and they just slapped a "Max II" sticker on the IC7-G box.
"C" is the letter code that refers to the FSB speed:
A = 400 FSB (4 x 100 mhz)
B = 533 FSB (4 x 133 mhz)
C = 800 FSB (4 x 200 mhz)
The "A,B,C"s are all Northwood cores for the most part (except the 2.4A and 2.66B), the Prescott's use "E" and the Extreme Edition Prescotts are "EE"
I'm not sure if the 430W Antec will work........ I would imagine that it should, but that depends on how many other things you have running in your computer and what video card you pick.
You may find that you need to get another PSU, but I'd just try it and see if your rails droop too much.
ojibewa said:
my 2.4c 24/7 for months...
rock solid and stays very cool
