Hello guys, I'm preparing a new project and I will be having some plexi panels on my case. I want to drill some holes at them and I want them dead straight. I'm thinking of using cobalt drill increasing in diameter from 1 to 2.5mm which is the final diameter of the holes. Since cnc laser can't cut the plexi panel on the sides I have to do it with Dremel or a drill? Any ideas guys? Anyone did anything like this before?
Thanks in advance!
Thanks in advance!
