- Dec 27, 2008
Use gentle, intermittent pressure when drilling. Push and then retract. Pause. Then drill some more. That will help keep heat down. Patience is critical. One melted or cracked bore will cost you a whole plexi panel.
If you can't reduce the rpm of the drill like you would want, find some kind of 120v rheostat device to reduce the voltage to the drill.
http://www.ebay.com/itm/AC-120V-15A...505908?hash=item488d5fb874:g:QzAAAOSwdGFY0qQt
