- May 15, 2010
- Euroland, Denmark
Hello guys,
I am trying to run a dual boot W7 and W10, but suspect that the way i need to run them is not possible?
Windows 7 Pro is 32bit and Windows 10 Pro is 64bit.
Running on separate hdd.
I was told that all i needed to do, was install W10 on the second hdd and then w10 would figure out there was a W7, and then give me boot opens when i boot up. This did not happen.
I inserted my usb with W10, ran the installer, during first reboot, it picked up the w7 drive and forgot about the 10, so i went into bios, setup w10 as main drive, and continued the installer. Windows 10 was installed, i ran through the setup, but at no point did the dual boot appear. I got all the way into W10, and nothing. Restarted, no choice of w7. Went into bios, picked my W7, and booted up, this had now run into issues, and needed to run a self check before it was able to boot, but it did finally make its way into W7 (which is my main OS atm, while i test all software in W10, and make sure everything works)
Is it the 32/64bit causing issues, or have MS removed the dual boot feature? or did i screw up while doing this?
