- Sep 30, 2001
- England, UK
This might b a stupid question bur, If you add a duct to the side of the case how can u get the side panel on where the duct sits over the cpu.
chris_4130 said:This might b a stupid question bur, If you add a duct to the side of the case how can u get the side panel on where the duct sits over the cpu.
Tecumseh said:
Carefully!
Some side panels are a PITA to get back on with a
fan or fan/duct mounted to them. You have to
"measure twice and cut once," as the shop guys
always say.
The HP duct system is elbow shaped so they can
suck air from the back of the case. This leaves their
side panels simpler.
MySTiCuSS said:I'm going to make a duct will this be a good one? Because i don't want to mod my side panel!
