- May 7, 2012
- Denver Colorado
Sooo this is an odd mod idea but I think I need to figure it out. I am basically wondering if it would be possible to integrate a blue-ray/dvd combo drive into a fan controller that takes up 2 bays. I found a specific fan controller that looks like it might work. Here is a link to said controller. To save you some time however, I will post a pic for explanation of my idea.
Looking at the area towards the bottom of the controller(Where the logo is), I think it might be possible(and also bad A**) to have a disk tray emerge there. if you look at this picture of the back of the controller...
I might try to remove the PCB and install it instead horizontally on the top part of the internal disk drive. I would need an extension ribbon for the LCD control, but I think that is obtainable. Also, I am relying on the chance that the LCD is not attached to the PCB in some difficult way.
I would love some comments on this idea, and if I attempt it I will make a build log and a step by step guide. The reason I am interested in this project is because my *extremely* expensive case I just bought only has a duel drive bay. I would be making this device for my latest build which can be found here: http://www.overclockers.com/forums/showthread.php?t=709098
