- Jul 29, 2001
warlock there is a solution (it might intereset you too theguywiththeha).
You can connect the 2nd and 3rd L5 bridges then use GCPUID (My sig, red link) to change the multipliers upto x24 from windows.
This way you don't need to open up your case or do whatever modding to get to a speed you want to get. You can also make a certain multiplier to be set at windows startup (read the readme file)
