- May 25, 2007
- With Yahweh in Colorado
i love the e5200 I have at work running at 3.0Ghz on stock Volts. sure it could go higher but no time to test.
I did use the stock cooler with my Q6600 for a while and it ran with workable temps at 3GHz too.
The stock all Al cooler on the e5200 is puny compared to the stock Q6600 cooler. So, its not quite apples-to-apples. I get your point, though.
Yea is it one of those half-sized all-aluminum heatsinks? They are tiny.
Nice undervolting ! Thanks for sharing !
Yep. I thought I had seen the 1/2-sized one's before, but this one seems to be even smaller. I could be wrong, though.
No easy way to load up the CPU now. It runs the unRAID OS. I'd have to shut it down, and put in a different HDD and then install windows. I want to eventually run a VM on it, but that's going to take some time to figure out.
Trust me, though, I've got this CPU and mobo running on MINIMUM juice!
I have it set to 333x6 which is a big FSB OC (I wanted good RAM bandwidth), but the multi is dropped to the min. This is an overall underclock to 2GHz from the stock 2.5GHz. If I used EIST and C1E there is no way it would drop the vcore as low as I have it (0.856v). Right now its in an eternal speedstep state, but at 2GHz its way more than plenty to power this file server. LOL! I've got all the mobo voltages dropped as low as they'll stay stable. RAM is set at 1.8v at 800 5-5-5-18.
Well, to squeeze out few more drips of power efficiency juice (not much though), increase or mod the psu fan with higher rpm one to make it cooler, add fan and few heatsink to the mobo's mosfets and inductors that are surrounding the cpu.
If you let the system do it's thing with EIST and C1E the min speed would be 6x200=1200MHz. Or you could run it at that speed straight up, I bet it would still be plenty of speed for unRAID. Why not give it a shot and see? My e1200 runs at 0.9V with Speedstep/C1E enabled.
I am a touch jealous of unRAID becuase of its disk-space efficient and expandable. Wish I'd known about it before getting WHS although that has it's own useful features with little hassle.
I may install some sinks (I have some extras), but if the MOSFETs and inductors feel cool to the touch I probably won't bother.
