- Oct 10, 2006
- san antonio, TX
- Thread Starter
- #21
posting from my e8400 now, so yup it was the bios.
I have the 680i chipset with the ASUS P5N32-E SLI and could not get the E8400 to post at all..even after updating to BIOS version 1302(I believe that's correct). I plugged the E6750 back in and got a perfect boot.
Before I ordered the E8400, I called ASUS tech support to see if this CPU is compatible with my mobo. Tech support said "yes". After installing the chip and not getting any results, I called ASUS again. This time a tech rep. advised the E8400 IS NOT compatible with this particular mobo..even if it is a socket 775. It just will not support 45nm. So, I reluctantly boxed up the E8400 and sent it back to MWave.com for a refund. This was quite disappointing.
erm.. i have a friend with this combo, i've seen it working. could it be a mobo revision thing?
look in cpuz if it says NV650 or a 600NV based chipset it supports it..now it could be the old NV570.. check cpuz for me?
it is possible that hte memory is not compatible
there should be a beta bios to add E8400 support to that board. cause i know for a fact all nv600's support wolfdale cpus.
