- Jul 23, 2007
So I finally decided to start messing with the FSB voltage (vs the overall CPU voltage). To get stable at 4Ghz, I used to have to go in the 1.5vcore range. Now I can do stable (over 21 hours) with much less vcore by increasing the fsb voltage..
A couple of questions on this. Are there any dangers to raising FSB voltage or is this something people do all the time? Also, look at the screenshot (attached) and tell me whether you think this is stable...
Finally I want to push it a little more.. how would you go about it? My ddr2 800 is running at 1000, but i dont think i can keep going 1:1, so what do you all recommend?
Thanks
Thanks
