- Dec 19, 2005
- New York
I am sure most of you have seen my QX9650 on Water thread and have seen the massive capability of Penryn/Yorkfields 45nm halfnium technology. Even on my quad core I was able to achieve astounding clocks. In a short wrap up of my QX experience:
All of the following information was taken from member Chrisch @ XtremeSystems.org in his results thread. The guy got his hands on one of the first E8500 Wolfdale ES chips. He ran on it a P5KE and water cooling. Here comes the madness:
SUPERPI 32M @ 4.75 GHz,,, wow..
Their you have it folks, assuming retail wolfdales will perform relatively the same as this ES counterpart you should assume to expect around 200 to 300 mhz more than a quad on your overclock with the lower TDP dual core. As you can see, he also had no problem taking FSB all the way up to 517 on the dual core where as my quad was limited to 450/455. So, I think that throws the FSB wall question at under 5.0 Ghz right out of the water. We still dont have any LN2, DI, Phase data so hopefully it still does not have a wall at higher FSB's.
As you can see, even with the higher TDP of the quad cores they are extremely efficient in the new 45nm process.4.0 GHz 24/7 stability is available to you @ 1.36 vcore (stock max intel recommended volts)
4.2 GHz 24/7 stability is available @ 1.48 vcore (stable but 66*C to 70*C)
4.56 GHz Full gaming (ie: crysis), benching, 3d stability for hours @ 1.60 vcore
4.70 GHz SuperPi 1m 9 Second Barrier Broken in Vista (maximum SuperPi1m shot)
4.79 GHz Maximum clockspeed capable under water cooling for screenshot.
