PROBLEM SOLVED: disconnected PWM cables, and the pump works properly now.
Should've thought of that.
Hello,
I've contacted EK but they haven't gotten back to me, so I'm posting here in the hope that someone has an idea about how to fix this.
I have a loop with just a pump, two full-cover EK 290x waterblocks, and a 60mm 280 radiator.
I'm using dual serial 3.2 PWM pumps, and the radiator size is 324x144x60mm.
There's only one way I can run the tubing through the GPU blocks that allows the pump to work - when hooked up this way, however, the cards aren't cooled - 60º idle, and then straight through the roof until they die when I try to do anything interesting with them. I don't believe that the water is properly flowing through the blocks, since the cards are hot to the touch, but the water in the tubing directly above is lukewarm at the hottest. I also can't see how it's a configuration that should work, even though I thought that any port could be used as an inlet or outlet. Otherwise I would think I had bad contact between the GPU and the block, but I don't think that's it.
I've attached a picture of what is and isn't working. Any ideas?
Hello,
