- Jan 10, 2012
I just loaded a fully watercooled sabertooth 990fx R2.0 board and 8350, that makes 4 blocks, into my test bench .
gpu is a gtx970
pump, d5
rad fans, 3 +1 for the board.
psu is a 430 evga
and yes, I'm breaking my rules and using a two molex to 6+2 pcie adapter .
the rig never posts, it gets to the cpu led on the board, stays there a minute, then winks off, never spins a fan, I can't tell if it's spinning the pump.
I suspect the psu is not going to even post this thing and all my other rigs, with larger psu's are up and running, doing things for a while and the one I can rob stuff from is another 430..........
does this sound like a psu issue to you?
gpu is a gtx970
pump, d5
psu is a 430 evga
