- Jul 24, 2002
- Seattle, WA
These are first generation 36GB raptors, aren't they?
Vista's kickin' your a$$. I'm in dual boot config now w/ the 2 74ADFD's. Here's a comparison of HD Tach and HD Tune on XP using 2x74GB ADFD's in a 70GB stripe:fritzman said:Frankly... I am a bit disappointed.
Newer raps I believe. ADFD in the HD Tach shot should mean 16MB Cache, single platter.These are first generation 36GB raptors, aren't they?
Well, those raided raptors have really good seek time and low cpu imo !
But I guess from your sounding, you expect "a lot more" compared to your old raided seagate drived ? Am I correct ?
Sound's like your next drives will be the killer iRAM in Raid !
.... I figured out the hw issue, replaced the power connector, and now the controller is doing a rebuild. The performance seems fine even during a rebuild. I can't tell any difference.
Thanks for your thoughts mate... I think you might be right. I might have a play with stripe size a bit and see if that makes any difference, and I don't know whether it will change much, but the X3220 chip (G0 step) goes in on Monday.
Then it's just the wait for the 500's to arrive!
Not trying to lure you back to ICHxR raid , just curious, could that problem was causing your ICHxR raid failure ?
possible. The power connector might have been going out for a while.
