Hello,
I have a mysterious problem.
It looks like this fellows graphs.
http://www.ocforums.com/showpost.php?p=4662441&postcount=110
The problem is that I have to enable volume-write-back-cache to significantly improve my overall speed. I made the entire array Raid 0.
I am using an Abit IP35 Pro with Intel Raid. The drives are two Seagate 7200.10 320GB drives.
My question is why do I have to enable the feature while other don't in order to have fast arrays. (I don't mean the people who set up a Matrix array. I know where their speed comes from. ) Is VWBC bad for the system at all?
Great thread you guys. Keep it up.
Hi Bing,
I appreciate the welcome. I have certainly enjoyed your discussions here regarding Matrix Raid! The Raid 0 benchmark seems like it's not so stable...ie. large fluctuations from 290MB/s to 400 MB/s. I've looked at other Raid 0 benchmarks in this thread and many appear to be more 'flat'. My Raid 5 does seem ok. Here are the HD Tach results. Again, the Raid 0 is not smooth like others have seen. But if you think it's ok, then I have no argument against that
BTW, I did pull the jumpers and my RAID 5 is indeed set to 64k strip size and 128k for Raid 0. I must say this is definitely the most responsive system I've had.
Wellcome to OcF Knight !
Thanks for the compliment, and you have an interesting question there !
Well, you've seen it your self that obviously WBC is increasing the STR/average transfer rate right ? Except for some trivial increase in CPU utilization, but I've tested it intensively in the past, it doesn't affect significantly on real-life usage nor at benchmarks.
Honestly, until today I still don't know what is the con by enabling WBC, I've traced carefully on the memory usage, and still no proof that it eats up more resources like memory usage.
But, I've been "guessing" that these WBC might have a bad effect on single core CPU, but alas so far there are not many samples reported yet to proof it.
Oh, sorry, I guess I wasn't having enough sleep when I responded to your 1st post.
Ok, if you mean those jaggies curve, have you disabled those background tasks like anti virus, firewall, running applications if any, disk defragmenter and etc ?
If you see my benchmark results, all those were created with disabled background tasks like my AV, firewall, defragmenter, any running applications, and .. internet, yes, sometimes internet ccould affect the benchmark result especially with that pesky Windows Update enabled.
Ok, this is not the 1st time I heard that "my rig feels so responsive", congratulation and glad you're enjoying it.
I know, most ICHxR Raid basher will say, Yeah right, how come your feeling can be an objective benchmark ? LOL, yes, have to admit that they have a valid point in that argument, nothing against them.
Its just I've been building many rigs for a very long time, these thing really makes significant different, anyone agree on me with this ?
Again, a "very subjective" matter, but don't ignore the statistic once they're become a significant numbers in the chart !
Most responsive, eh? W/ over 350 STR...that's sick...not right...I'm MAD envious.
What do the jumpers do on SATA drives anyway? Something to do w/ spread spectrum, 150/300, or NCQ? I suppose they'd be different from drive to drive. I'll have to take a look @ WD and Hitachi sites soon...unless any of you know off the top of your head?
Thanks!!
PS. The wacky lines in HD Tach don't mean much. If you really wanna test your stuff, copy some files...or maybe do some extraction tests. Nothing says lovin' like real world pron moving.
You're right....After looking through some previous benches from other members, it does seem like 350 MB/s STR is indeed nice But of course, I couldn't find any others with 4 X ST325410AS to compare so it's not apples-to-apples. I think fritzman had a setup with 4 X Perps once?
I plan to copy some large files between drives, etc. to test the speed of the RAID arrays. But just from installing XP 5 times already, I can tell it's at least 2-3 times as fast as my previous non-RAID computer.
Which version drivers and software are people using with the P5K Premium (if you're NOT using Seagate drives)? I've read about issues with non-Seagate drives on that mobo for some reason, could be some bad ICH9Rs around or something else but to be safe I went with the F6 drivers and software on the CD - 4x Raptor Raid0/5. The install is so fast I may just try the newest ones for fun though unless anyone else can say yes or no for sure.
Want little boost on your own ego ?
Try PCmark and post your bench's score at the Orb and compare your rig there with other rig around the world that has same CPU, similiar mobo class, same RAM and same OC clock speed !
Of course beware of iRam owners, your's can't compare with that cause its solid state "RAM" drive.
Yes I have tried both. You may not be aware of it though but there are some threads on Asus forums regarding the P5K Prem having serious SATA RAID issues, especially with non-Seagate drives. Remember how you said 'Seagate has been with Intel...' or something like that to me? One of their techs advised to use the drivers and software off the C. I used those, and then decided to reinstall and use the newer ones. Both seem ok with Raptors so far.
NET STOP PDAgent
NET STOP PDEngine
NET START PDAgent
NET START PDEngine
net stop "automatic updates"
net stop "DHCP Client"
net stop "DNS Client"
net stop "Fast User Switching Compatibility"
net stop "Help and Support"
net stop "HTTP SSL"
net stop "Print Spooler"
net stop "Talking Alarm Clock user logon monitor"
net stop "Secondary Logon"
net stop "Shell Hardware Detection"
net stop "Universal Plug and Play Device Host"
net stop "SSDP Discovery Service"
net stop "Task Scheduler"
net stop "Themes"
net stop "User Profile Hive Cleanup"
net stop "WebClient"
net stop "Windows Firewall/Internet Connection Sharing (ICS)"
net stop "Windows Time"
net stop "Windows Audio"
net stop "Wireless Zero Configuration"
If I get enough vote of interest for these amazing BartPE and DriveXML tool usages, I'm thinking to write down a dedicated guide on how to prepare and use it in this special Intel Matrix Raid environment.
Consider this a vote-I had 2 drive matrix raid 0/1, and I just added 2 more drives. I'm restoring the disk image using acronis true image, and it's taking roughly 4 1/2 hours. I can't imagine why it would take so long, but I'm all for trying something else that will allow me to restore images before I'm dead of old age.
