Can one of you start from the beginning? Like the correct jumper settings? I have a set of creative 4.1s I want to use with the onboard audio since I heard its better than my SB Live.
you shouldnt have to mess with jumper settings. There are 2 caps on the board listed on page 3-10. There should be 2 caps located on pins 5-6 and 9-10. Other than that, you should be good to go. You need to find those Nforce control options though. I would get the latest drivers from Epox's website.
