ALL YOUR BASE ARE BELONG TO US
just slightly offtopic here, but zakelwe, here's something that's concern ya:
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=251068
a pair of athlon 64's, both with their heatspreaders popped
and LOAD temps are 34 degrees celcius with air cooling (zalman)
took me a while to pop the second one, cause the first time it was a *really* close call, but otherwise just get them four razor blades, twist, squeeze, and pry and you should be fine...
anyways... for the topic
hey walldow, how ya doing?
deepest apologizes for not writing ya for the longest time...
i was really busy [ again
] for the last whole bunch of time ... BUT
BUT
with a hex editor and some crazy dude in europe, we're getting very close to the first working SOFTWARE VOLTAGE ADJUSTMENTS, for 5700/5900's ONLY
so dun solder anything to ur card yet
gimme maybe another few days and i should have it
but otherwise as undoubtly you've noticed, the voltage controllers are basically the same
though you can max out a bit higher on the ram
and also i dunno about you, but my card:
http://www.colorful.com.cn/UpFiles/Product/27/135/5700Ultra_CH_b.jpg
maxes out at 600/1050 on stock cooling, and with a bunch of stuff soldered on it, 650/1100 is good; 1200 on the ram shouldn't be impossible: its got the same voltage ic as the 5800
on yeah, AND LAP YOUR RAM... i dunno how to emphasize the importance of this, but lapping that DDR2 HELPS
hold on, i gotta go do something, be back later
