Hmmmmm......artifacts in 3DM03 under CPU tests only. Testing FSB 220 MHz, with 1:1, CAS 2.5-3-3-6. Vcore setting in BIOS at "Auto", Vdimm at 2.75. CoolBits clocks at 420/1150 (575MHz DDR). All 3D GPU rendered tests run at good frame rates, with zero distortions. Only the CPU tests artifact. Going to run a few more courses with Vcore upped by .25 volt. I might alter the 1:1 as well to see if it's my system RAM which is the problem. Problem there is that at 5:4 divider, with 220 FSB the RAM will be underclocked at 176MHz base frequency (DDR352). I'm definitely thinking the PSU itself is wasted. I can't afford a new PSU just yet, as I have to get a new machine built within the next couple of weeks. [sarcasm]The party never stops.[/sarcasm]
back with more later
DarkMatter13
