Hey everyone,
I'm about to place my order for my xspc kit and I can choose either a ex360 with 7/16" tubing or an rx360 with 1/2" tubing, both will be powered by a dual bay d5 res. I know tubing doesn't make a difference, but I'm more stuck on which radiator to use. With the RX it is bigger so I will probably only be able to use pull or push and the ex I should be able to achieve push/pull with no mods. I plan to try the stock xspc fans but will most likely use noctua nf12s. Any thoughts or suggestions?
Also I am just going to be cooling my oc 3930k with it and in the future will add another rad and gpu block when I upgrade the gtx580.
Thanks
Thanks
