- Jul 12, 2007
I want to get an extra fan to supplement the existing stock fan but I don't know if I actually need one. Still, I'm looking for a fan that has a noise level of 25dba or less at its lowest setting and 82.9 CFM or higher at its highest setting. My overall usage will be applications on a overclocked and (possibly) unlocked system in an Antec 300 Illusion case with stock fans.
Here are a couple fans I'm looking at.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200021
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106153
Are any of them good and do I use them as push or pull?
