- Sep 9, 2011
Hello, it seems like I need the help of this great community here again
I'm just terribly confused about my case fans, my case is an Aerocool iCurve which has two pre-installed 12cm fans, one outtake at the back of the case and one intake right infront of the HDD cage, so far so good.
I added two generic (cheap, 5 bucks on Amazon each ) additional 12cm intake fans to the side of the case. I know I can't expect much from such cheap fans but the airflow is actually quite strong though my problem lies with the cabling.
All four fans, also the pre-installed ones come with two type of connections on their cables, one 4pin IDE style molex connection and one 3pin motherboard-style connector
My be quiet! PSU has special fan lines, black and white cables with these 3pin and 4pin molex pass-through connections and a sticker that explicitly states that no fan should be attached with both of its connectors.
Now the crazy weird thing, the pre-installed fans always seem to run at the same decent speed, all fine. Though my additional fans rotate fairly slowly no matter if I use the 4pin or 3pin connection.
If I now ignore the warning sticker and connect each of the four fans with both, 3pin and 4pin and only then! the speed of the extra fans suddenly doubles if not triples
I'm completely lost here because this doesn't make any sense to me, I only want one of these extra fans run at full speed while the other should run slower though I can't understand why that happens, there's no fan controller in this case and neither of them is connected to the motherboard all go directly to the PSU so it would be nice if some of the pros here could shed some light on this
Thanks in advance!
Thanks in advance!
