D
Deleted member 94297
Guest
I couldn't think of a better title, sorry...
Recently my friend has given away 2 hard drives to me, so I put them in and made a 3 HDD RAID-0. I installed the system, everything was okay for about 6 hours. The system was on heavy HDD usage - Windows installation, software installation, downloads, etc. Then my computer started to freeze for a a second every 10-30 minutes. I started to worry, so I checked S.M.A.R.T. status, and everything was in order. At that point - my PC wasn't on a heavy HDD usage, only downloading some files at approximately 2mb/s, which is pretty much nothing for the HDD. After few more hours, the PC started to freeze every 1-2 seconds for 10-30 minutes. After I restart it - it is back to normal until I resume the download again.
During those freezes, I couldn't hear the HDDs working, nor the indicator on the case showed any HDD activity. So basically - HDDs stopped working. I took out one of them, reinstalled the system without the RAID, and it still was the same (but only when on heavier load than system installation). Then I took out the second HDD, and left only one with the system. And so it isn't freezing, but according to HDD testing I did, the read/write speed is jumping from 5 to 60 megs every few seconds during the test. I'm not doing anything else with my computer during the test.
So I'm wondering what exactly could cause that? When there's been 3 HDDs - maybe my degraded PSU which came with my case and originally is 420W.
And it isn't a HDD failure, since HDDs are working okay when they are singled out.
Also my CPU is working fine on full load, memory is working fine on full load either...
