- Jan 12, 2013
- on your window sill staring at you
Ya I got asus rampage IV extreme
yes I do...
You cannot control those fans with your motherboard's PWM header. They are not PWM fans.If I'm powering the fans threw a molex connector and just us PMW for the fan control will that be using the full amp of the fans? Like right now I want run 6 GT AP-15 fans for my 2 rad, fan say 0.083A at rated but to start it is 0.36A if I do the math at boot up will pull 2.16A for 6 and 0.498A after that correct but If I us molex will that still be the same?
Because they're connected directly to your motherboard and your motherboard allows control of non PWM fans. The way it does so is to regulate the voltage to those fans. A PWM signal by itself can only control PWM devices.
If the OP wanted to control the fans with his motherboard, then he would need to connect the fans directly to his motherboard so that it can provide the current to those fans. If he has enough headers, then that's possible. It is not advisable to connect all six fans to a single header as that will fry things.
he has 8 connectors... says the website
oh well there is alway this option there for you. curious what case is it?
