I'm running out of those 4-pin cables for my drives + fans. I don't want to hook my fans on the same chain as my HDD and my DVD burner because they'll draw all the currents off.
I however have 2 spare outlets from my PS, one is for SATA drive and the other one is looking kinda weird, I dunno. Also have one extra floppy outlet. I was wondering if there're any adapter or converter I can use with these outlets for my fans so that they won't draw the current from my drives.
Would it be better that I need a fan controller that can help me control 9 fans in my system: 1x120mm, 1x92mm (for the SLK947U), and 7x80mm? It's very noisy. So I need a suggestion to what I can do about these fans and their cables (all of them use those 4-pin outlet). I need a good fan controller that can control as many of my fans as possible and only require one 4-pin power input and split into different output for the fans that it controls. I have one spare 5.25" bay and one 3.5" bay. I don't need anything fancy, rather prefer digital button than Knobsince my case has a front panel that often closed.
Thanks
Thanks
