Hello , I'm looking for some advice on a problem I have with my cooling. The problem is that my CPUs cooler exhaust (Noctua NH-U9B SE2) faces up at my case, which would not be a problem if it had a fan there. Since I don't it is starting to overheat in the hot summer weather.
I would like to solve the problem and not spend a fortune , so I'm looking for some advice from you guys, because I don't know what would be best, replace the cooler, case or motherboard?
motherboard : gigabyte 990xa-ud3
case : PRO917B TITUS X
cpu socket : am3+
Thanks for any advice guys!
cpu socket : am3+
