Hail all, first time here and I have a question on fan placement! First I'll give a quick low down on my situation, lately I've been getting some hot spells on my CPU and case temps running around 55-60c Idle for cpu (which is a 3.00 Prescott) and 43c on the case temp.
I thought that was a bit hot so I started switching around fans and what not, currently I have a couple 6000 rpm vantec tornados ordered with a new GPU fan as well. Before I switched the flow the side fan blew in, the two back blew out, and the two front blew in.
As of now after switching the flow I have 2 fans in the front blowing in my, PS of course blowing out, 2 fans in the back blowing in, and a fan on the side blowing out, all 80mm. This is all before I switch them out for the new vantecs coming hopefully sometime in the next couple days.
Now I'm around 50c idle and 36c case but that's before testing as it is late and I'll get to that tomorrow, but the problem I was involved either hard locks or complete booting out of any 3D app or just a freeze.
Well now that I've rambled on I want to ask if what I changed to flow to is any better than what I had it as, to me it does but I want to get some more oppinions, and ANY other cooling ideas or tips would be GREATLY appreciated . Hopefully this will get some replys as I'll check it when I wake up!
EDIT: For the temp readings I'm using MBM5
Thanks all!
-Jim-
Thanks all!
-Jim-
