Hey guys.. For the upcoming project that I'm planning I will be using the EK Coolstream XE 360.. It's a pretty thick rad and I want to use the Corsair HD120 fans on it. I did check the static pressure and air flow and they are pretty similar to the Noiseblockers I already own. Do you think they are good for rads? Is pull configuration enough or am I gonna need push/pull conf?
Thanks in advance!
Thanks in advance!
