- Oct 7, 2015
- Lindfield, Sussex, UK
Fans, Airflow, Radiator placement and much confusion. Advice & guidance please!!
Hello everyone,
I'm building a replacement PC and have a few questions that I am having difficulty finding satisfactory answers for.
I have already purchased a case, (that was going to be a straight transplant of my old system) but have since decided to go the whole hog.
So far I have .....
Corsair 730t case
Asus X99 deluxe mobo
i7 5930k processor
32gb HyperX DDR4 266 ram
2x Asus GTX 980 graphics cards.
XFX Pro850w modular psu
A random collection of SSD's HDD's Optical drives to complete the build with, (or be upgraded / replaced as necessary).
I want to water cool the CPU and GPU's but with my budget and experience I have decided to go with AIO options for both.
Due to the position of my tower, (under my desk and against a bookshelf in the corner of the room) I am going to be fitting an extractor fan exhaust in the back corner, (and on one shelf of the bookshelf just under the desk) to help with airflow and keep temperatures down.
I will be using one of the HDD racks supplied with the case for at least 2 3.5 hdd.
So my questions are as follows.
1: I am looking to use a Corsair H110i or H90 for the CPU and two EVGA hybrid 980 kits for the GPU's.
What is the best solution for mounting them please?
I have considered the following.
H110i in the roof of the case, EVGA hybrids in the front behind the 140mm fans.
H110i in the roof of the case, EVGA hybrids one front and one bottom.
H110i in the roof of the case, EVA hybrids one front one rear exhaust position.
H90 in the rear exhaust position and the EVGA's in the roof of the case.
2: I have never operated SLI before. Will these 980's operate ok in adjacent PCI slots with the hybrid coolers or is it best to leave a slots width between them and use a longer SLI bridge?
3: FANS!!!!!!!!! God it gets confusing. Do I need extra fans? Layout? SP or AF? Where?
4: Do the fans need grouping so I can control the airflow balance and reduce noise? If so what is the best way to control them all individually?
5: I want to control the Extractor fan from the PC as it will be practically inaccessible once installed and the computer is in place.
I am aiming to use a high cfm 140 to 180mm fan and would like to control it via pwm and a temperature switch so that it comes on only when needed and doesn't cause a gale around my legs when not.
Is there a suitable single fan controller out there that would work alongside all the other fans?
Sorry for all the questions.
I realise they may seem annoying to some of you but i have spent a couple of weeks googling, read many forums, heard many opinions but been unable to relate them all to each other or my personal requirements.
Some experienced advice or pointers would be incredibly useful, (especially if someone lives near and would like a free coffee for a chat and some advice).
Things I can't really change.
Position of the computer.
Major components, (they work for my budget and needs).
The case is a possible swap but it will need to remain less than 560mm deep , 700mm tall, and around the £100 mark so I can balance the sale of the 730t if needed.
Many thanks to you all.!!!!!
Hello everyone,
So far I have .....
Corsair 730t case
i7 5930k processor
