- Nov 15, 2012
Hi everyone,
Just another question I have and this time about fans. For my CPU Cooling in my future build, I will be using a Cooler Master Hyper 212 EVO and I was planning to use 2 fans since I am getting LP memory. I was considering picking up 2 Corsair SP120 High Performance fans but after watching some videos about the 212 EVO and the SP120 fans, I feel as though as they won't be compatible. I really like the Corsair fans, they have put a lot of engineering and science into them and I thought that they would have given me maximum performance.
Another factor is that the Corsair fans use a 3 pin connector. I was hoping that they would have 4 pin connectors since my motherboard only supports 4 pin connector fans. This is a bit of a drag. I think there are some adapters that convert 3 pin into 4 pin (Not too sure)
So I might not be able to use the Corsair fans. My questions:
1. Would the 2 Corsair fans be compatible with the Hyper 212 EVO?
2. If I were to use the Corsair fans, is there a 3 pin fan connector to 4 pin fan connector adapter?
3. Are there any other fans that would deliver high performance and be compatible for my needs?
Thanks in advance
My Build:
Processor: Intel i5 3570K
Cooling: Cooler Master Hyper 212 EVO
Motherboard: Gigabyte GA-Z77-D3H
RAM: Corsair Vengeance 8GB 1600MHz LP
Graphics: Sapphire Radeon HD7850 2GB GDDR5 OC
HDD: Found some around the house: 2 160GB 7200RPM (Will get SSD later on)
PSU: Corsair CX600
DVD Writer: Samsung DVD Burner
Case: Antec One
Thanks in advance
My Build:
PSU: Corsair CX600
Case: Antec One
