- Jan 26, 2004
- Charleston, IL
ok. yesterday i flashed my bios to the 1/31 beta. i tried some more OC'ing since i wasn't very stable with the 11/27 bios. i can get up to 185x11 fairly stable, but i have to pump my vcore up to nearly 1.8 to do it. and anything past 185 i have to take the vcore to 1.8 or higher, and then my computer thinks my cpu temp is going over 60C even though to LED from my waterblock diode is reading about 30C, so my computer just restarts itself
whenever i try to run any benchmark.
also, no matter what FSB i have it set at, i'm failing the Prime 95 torture test in under 5 minutes every time due to rounding errors. I've tested my ram with memtest86+ at every speed from 166-200 for 10+ hours and i've gotten no errors so i'm pretty sure that's not the problem.
I can run BF 1942 and Desert Combat for hours on end with my FSB set at 185x11, but i can't run the torture test at 166x11 for 5 minutes, which doesn't make sense to me.
So do you think there's something wrong with my motherboard that's RMA worthy? or perhaps i got a bad cpu out of the batch...
i'm runnin on
XP 2500+ barton (i'll check the serial number later, but i'm pretty sure i have a newer locked one)
DFI NF2 Ultra Infinity w/ 1/31 beta bios
1gb Geil Ultra platinum PC3200
Sapphire 9600 XT
Koolance EXOS watercooling
Raidmax 420w power
If anyone has any ideas that might help fix my little problem, i'd greatly appreciate it
thanks
i'm runnin on
Sapphire 9600 XT
Raidmax 420w power
thanks
