Davan
Disabled
- Nov 2, 2005
Over the holidays through presents and my own $$$ I have assembled my first watercooling configuration and I had a few questions that I cant seem to find easy answers to. Was hoping that the more experienced people here might be able to answer a few of these questions.
First off let me start by saying what parts Im using.
Swiftech Apogee CPU block
MCP 655 pump
Black Ice Extreme 3 Rad with 3X Delta 120MM fans (havnt arrived yet so using 2X Coolermaster 120MM fans for now)
1) Can anyone tell me what "ID" and "OD" means? I cannot seem to locate a quick definition of these two abbreviations
2) Are there generally any negative repercussions for mixing different sizes of tubing? I bought 1/2" tubing but for some reason they didnt send enough 1/2" barbs for me assemble everything. So I can either go buy some tubing to fit the smaller barbs that came with the larger barbs, or I can order some more 1/2" barbs and just use all 1/2" tubing. I doubt I can find 1/2" barbs local however.
3) How can you tell which one of the two fittings on the pump is the output? Im assuming that the one on 'top' is the input and the one that is parrallel is the output but Im not sure. And with water moving Im not really sure if its coming or going.
4) What is the best way to leak test a system? I have everything connected up with just a power supply and I can power it on with a metal clip but obviously I cant sit and hold it there for 24 hours so Im not sure how to keep it on without actually pluggin in a motherboard (which I dont want to do until Im sure it wont spray water all over the place)
5) I purchased a single container of CoolerMaster Thermal Conductivity fluid - and its only 500ML. How much physical liquid does it take to fill a watercooling setup with my general properties?
6) And finally, what is the best way to fill the system? I purchased a resevoir (I wasnt 100% sure why at the time) but pouring water into it is somewhat awkward. Until I fix the leaks that I have from the fittings question in step 1 Im not going to jump to too many conclusions, but do you need both a resevior and a T junction and fill line? Or does just a resevoir do the job? What are the advantages/disadvantages of each?
7) The parts came with plastic clamps, are the metal clamps I can buy down at home depot going to be preferrable? Additionally, on the Apogee the hoses are so close together coming in and out that I had to kind of piggyback the clamps on top of each other - Does anyone know a better way to do this?
Sorry about all the questions and thanks for the responses! I just want to do this right the first time.
MCP 655 pump
