i guess you missed my post with all the fancy linkage to various rads.
no go with a separate res, you can only use the built in res when its vertical.
and no those rads are costly and why i like the MCR series.
If you're going to get a res, either get a separate res or one of the XSPC res tops for the pump.
Personally I've used a t-line in two rigs......and will NEVER use another one. I HATE filling and bleeding a t-line....
I know, right? That's the worst thing I could suggest.What????
OMG... Less performance? How sacreligious! LOL, j/k
I find the T-line super easy, but mine is outside of the case, not inside. Inside is a little trickier.yep, and a res took me sub five minutes to fill last night LOL! Nah it's just personal preference on my part, I refuse to use them after the last rig I built gave me so much grief.
I don't like those herbie chips. I use hose clamps. The ones you use a screwdriver to tighten. Herbies can be undertightened, and if overtightened they can pop off. They are plasctic. I don't trust the clamping power of plastic.
NOTE!!! you selected the wrong pump. the XSPC res top will only work with the Swiftech MCP350 or MCP355.
http://www.petrastechshop.com/ladd1mcin12p.html
When you're playing a game, the CPU and GPU are working their hardest - even if things are fine during the rest of your use, it'll crash in games if it overheats.
The restriction of the NB block and the MOSFET block might be a bit much. Honestly, I would leave the NB and the MOSFETs alone. You're not going to be voltmodding the northbridge or doing anything crazy with the MOSFETs, so whatever cooling they have should be fine.
Would two radiators, one gpu block, a cpu block, nb/sb block, and mosfet block be to much for one pump? Was thinking about including this in my loop:
http://www.frozencpu.com/products/8...IT_EVGA_X58-_Acetal.html?tl=g30c313s858#blank
