- Jul 25, 2012
I just built my first pc, besides my old pentium 4 socket 478 pc 5 years ago.
I'm waiting on a new powersupply to come (i'm using a 400w power supply I had laying around, ordered a sleeved coolmax psu to power this thing) and a new GPU. I will be getting a new GTX 550 TI or a radeon 6770.
SO, lets dig right into some specs.
My cpu is an AMD Phenom II X4 955 with a slight overclock from 3.2GHz to 3.4GHz. Here is my cpu-z validation.
Cool 'n Quiet
Prime95
I plan on overclocking this thing when I get my new PSU to 3.6GHz. Note this is not the black edition one, it's a normal 955.
For ram I decided to grab 2x4GB (8GB) of G-SKILL Ripjaw-X 1600MHz DDR3 ram. No overclocking on these.
My mobo is an ASUS M5A78L-M LX PLUS which uses the 760G chipset.
For cooling, i'm using a Coolermaster Hyper 212 plus with a blob of arctic silver 5 compound.
My case is an Antec 300, the old one without cable management. It's a little messy, but when my new psu arrives i'll fix it up a bit.
Temps are great, they would be lower if I turned off the thing in the bios that controls cpu fan speed. Speaking of fans, I have 2 front blue LED 120mm fans, a side 120mm fan, a rear 120mm fan, and a clear 140mm top fan. All of my fans are hooked up to an NCXT Sentry 2 fan controller.
Idle my cpu is at 25c (2c higher than room temp)
Load 40c (12 hours of prime95)
Here are some pics of my setup, but it will look much better with the new modular power supply i'm getting in a few days.
Cool 'n Quiet
Prime95
