hey all looking for some help or ideas of what i should do here.
big wall of text so please bear with me, trying to get as much insight as possible.
Approximate Purchase Date:about 6 weeks
Budget Range:$1600 to $2100 less would be better
System Usage from Most to Least Important: pretty much only gaming
Parts Not Required:e.g.: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts:newegg or tigerdirect or anywhere thats good.
Country:usa
Parts Preferences:by brand or type, intel and nvidia (maybe amd GPU if it could be better and cheaper.
Overclocking: Yes
SLI or Crossfire: Yes maybe tri in the future some time if anyone thinks it will be worth it? even on a pci 3.0 slot
Monitor Resolution:going to buy a new monitor a while after i build so as high as I can in resolution.
Additional Comments: well ive been looking at alot of stuff and decided to go with a z68 mobo cause i want compatibility with ivy bridge when it comes out and pci 3.0.
So im not sure if I should buy the stuff now that I know is good and tested that I know will not fail (probaly) and have no probs with. Or wait for the ivy bridge mobos and cpus to come and get them instead.Which I might have to spend more money on and not be a huge improvment and from what ive read the first ivy cpu wont have a unlocked multyplier.(which i want)
Also not sure of Sata3. sata2, sata and esata and the compatibility with the hdd or ssd that I get.
ok so parts I have in mind if I build now.
PSU:
havent looked into one much but want to do sli or crossfire down the road so anyone recomend one would be great. I was thinking 800w to 1000w.
HDD or SSD:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1083959&CatId=2459
not sure of the difference between them. Wanted them for the 7200rpm and the 64mb memory.Would also maybe get a SSD drive now or in the future for the right price.I dont need the 2tb space atm so a good hdd for cheaper or a SSD would be good. Not interested in raid either
Also what are the pros and cons of both? And really only wanted a good storage device for quicker gaming as I read that the storage device can affect that as the cpu will be waiting for it.
mobo:
Ok so this im having big probs with. Get a tried and true z68 or wait for the ivybridge ones to come out and get that for more money and a cpu then too.Also want at least 2 psi 3.0 slots and also at least 2 sata 6gbs slots.Also would like one that is good for OClocking.
Also want one to be compatible with Turbo Boost 2.0 Technology ,K-Series unlocked CPU and HyperThreading Technology. Not sure if the hyperthreading is important or not if I get a 2500k chip and upgrade to a ivybridge later if it will matter with that.
looked at a few mobos and the prob is that there is always the one thing missing that i wont and the other mobo will have it but is missing somthing else.
http://www.asrock.com/mb/overview.asp?Model=Z68 Extreme7 Gen3
this one has everything I want: nf200 chip so I can sli at 16/16 but only 1 pci 3.0 slot which is no good for when I get a ivy bridge cpu and have a pair of pci 3.0 gpu's. Not sure if I get 1 pci 3.0 compatible gpu and only a 2500k cpu I know the pci 3.0 will not work until I get a ivybridge cpu (which might be better so I dont spend $500 now on a pci 2.0 gpu and then spen another $500 later on a pci 3.0 gpu or get 2 pci 2.0 gpus now ).
So a bit of a dilemma, and also not sure about how a amd gpu works on a intel mobo?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157263
so this one has what I need but no nf200 chip so no 16/16 if I go sli now and also read some bad reviews on it.
http://www.tigerdirect.com/applicat...CmtB5ObkkzCjCVqHCjCdwwp&cpncode=20-81879013-2
this one looks good, has 2 pci 3.0 slots, 4 usb 3.0 ports, but no nf200 chip and has a intergrated gpu ( will probaly buy the gpu a bit later then the rest of the parts so this will let me use the computer in the meantime I think? does anyone know?) Also not to sure on the differences between this and the deluxe gen 3 and which one is the best for me.
http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z68VGEN3/#specifications
also has 2 pci 3.0 slots, only 2x 6gbs sata ports, no nf200 and also has intergrated gpu. Also less pci slot altogeather so not sure how goos 2 gpus will fit in and leave enough room to breath. especialy if they are big.
http://www.newegg.com/Product/Produ...-na&AID=10521304&PID=4176827&SID=wia9geyxmet4
well this one has the pci 3.0 , also not sure how important usb 3.0 are, but I will be using a usb mouse and keyboard so if the usb 3.0 speed helps that all the better. also has 2 sata 6gbs port and one is shared with a esata 3 port which not sure how that works.
or this http://www.newegg.com/Product/Produ...-na&AID=10521304&PID=4176827&SID=mu479uaiebts
well thats the mobos and I was also looking at some gigabyte and msi ones also.So anyhelp here would be great.
cpu:intel core i5 2500k
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7073161&CatId=6988
not sure if I should get this or the i7 2600k or i7 2700k
gpu: $609 Gigabyte Radeon HD 7970 OC (GV-R797OC-3GD)
was looking at this one because I will have compatability with pci 3.0 if or when I get a ivy bridge cpu and also this one kept up there with dual GTX 590's and also dual dual HD 6990 check this reviewhttp://hexus.net/tech/reviews/graphics/33697-gigabyte-radeon-hd-7970-oc-gv-r797oc-3gd/?page=6
so yeah not sure if i should get this one and get onother later on or get 1 or 2 pci 2.0 gpu's and keep them and the sandybridge cpu for as long as possible.
so any advice on other good gpu's would be great and I would rather go with nvidia any way but am very intereted in the 7970.
CPU cooler: any that is recomended, want to do OClocking and want a very good one.
Case: also any that can be recomended
thermal paste: any recomended
OS:$ 140 windows 7 pro x64
http://www.tigerdirect.com/applicat...CmtB5ObkkzCjCVqHCjCdwwp&cpncode=20-81879441-2
RAM: any that is recomended Im not sure how muh I will need though.
well I think that is all as of now, everyones help is greatly appreciated
links working know ty
Country:usa
Overclocking: Yes
PSU:
HDD or SSD:
mobo:
