Ok first off some background info:
This is my first build ever so I'm pretty nervous about buying all the right parts, putting them all together, then overclocking and having everything work out (fingers crossed). I'm also a college student so I pay to attention to price very closely.
I have been using my p4 3.2 for the past coupe of years doing minor upgrading so I could still play the latest games. It's time to do a big upgrade as I'm just not getting enough FPS in online shooters (which is what I mainly play)
I own a Dell 2407 24inch lcd and I like to game at 1920x1200. After gathering various opinions on this I will probably install vista x64 on this machine. I'm going to MAINLY use this computer for gaming and very light video editing (i.e. using fraps to record myself ingame to make frag movies). I'm going to mostly use this PC to play the latest games, Crysis, COD4, UT3, Asassian's Creed, Dark Messiah, AOC etc. FPS is very important to me, especially in games like cod4 where if I dont have a constat 80-90 fps I can't play. And, I'd like to be able to do this at high settings with a high rez.
After reading the OC thread in the OC section I had my heart set on a q6600 but after making a thread on helping to chose a video card a fellow poster informed me that it is actually better to go with a dual core then quad core if all I mainly do is game.
And the last bit of info... I do want to overclock, my goal is somewhere around 3.5-3.6 (without water cooling). I read somewhere that your memory speed has to match your cpu speed fsb, so I'm not sure if I picked out the correct memory.
It took me weeks to do all the research and get together all the information by reading reviews on different websites and reading all the theards here, so any help at all would be really helpfull
Anyways without further ado here are the pieces I've picked out so far.
WS= with shipping
CASE:
Rosewill R5604-TBK 0.8mm SECC Screw-less Dual 120mm Fans ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147033
$56.99
MB
GIGABYTE GA-EP43-DS3L LGA 775 Intel P43 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128347
W$= 109
CPU
Intel Core 2 Duo E8400 Wolfdale 3.0GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
$189.99
(Again this is where I dont know what decision to make. Either the above CPU or a q6600 which is the same price range)
PSU
Corsair 750W TX750W ATX12V Power Supply
http://www.provantage.com/corsair-cmpsu-750tx~7CSMC05E.htm
WS= $107.06
GPU
SAPPHIRE 100242L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102747
$159.99 after $30.00 Mail-In Rebate
Another question here would be is it worth it to upgrade to the 4870 (with the settings that I like to game at as listed above)
HD
Maxtor 1TB Serial ATA/300 32MB Buffer Hard Drive
http://frys.com/product/5524820
$ 159.99
RAM
AGAIN NOT SURE WHICH ONE TO PICK. WHICH ONE GOES BEST WITH MY MB/CPU?
1:
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
WS= $92
2:
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
$104.99
3:
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146731
WS= $72 after $25.00 Mail-In Rebate (THIS ONE IS ACTUALLY SIGNIFIGANTLY CHEAPER)
AFTER MARKET CPU COOLER
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
$26.99 after $10.00 Mail-In Rebate
RETENTION BRACKET FOR COOLER
XIGMATEK ACK-I7751 Retention Bracket
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
WS= $14
Thanks for all your help guys
WS= with shipping
CASE:
$56.99
MB
W$= 109
CPU
$189.99
PSU
WS= $107.06
GPU
HD
$ 159.99
RAM
1:
WS= $92
2:
$104.99
3:
WS= $14
