I am planning to build a computer to replace my 2005 Dell XPS and would appreciate suggestions for some of the components. My tentative component list is as follows:
Motherboard: Gigabyte GA-Z77X-UD5H
CPU: Intel i7-3770K
GPU: MSI N660-TI PE 2GD5/OC
SSD: Mushkin Chronos Deluxe 240GB Sata III
HD: Western Digital Caviar Blue 1TB 64MB cache - 2 units
OD: Lite-On IHAS124-04
Case: Corsair Carbide 400R
PSU: Rosewill Capstone-650-M
CPU Cooler: Noctua NH-D14
RAM: 16 GB - ? 2 8GB DDR-3 1600
Monitor: Dell U2412M
OS: Windows Home Premium 64 bit OEM
What are you planning to do with this compuer? Please be as specfic as possible.
The computer will be for all-purpose use, including gaming and editing of videos and photos.
What is your budget?
About $2000
Does this include a copy of Windows?
Yes
Does this include peripherals (a keyboard, monitor, mouse)?
Yes
Are you from the United States or a different country? Are you ordering from your own country or from across borders?
U.S. Ordering from own country.
Wherever you may be from, does the store that you are planning to order from have a website? It's okay if it isn't in English, we can manage. -
Looking for best prices, including shipping. Most components probably will be ordered from Amazon.
If you are from the United States, do you live nearby a Microcenter?
No. There are no Microcenters in Louisiana.
Do you have any specific requests with the build?
I need advice on the following components:
Case: mid-tower size with at least USB-3 ports in front and ideally also with Firewire in front for my video camera. It also needs decent protection against dust, as the room tends to be dusty. Appearance is unimportant, but function and ease of access are very important.
PSU: Is chosen size (650 W) adequate? Should have decent quality and efficiency, stable output, and quiet operation. Prefer modular.
CPU Cooler: Prefer quality air cooling over water cooling. Chosen cooler has good ratings, but I'm concerned about its size. If I do use the case I listed, will the cooler fit? Quiet operation is important.
RAM: I want to install 16GB as 2 8GB modules to leave 2 slots open for any further expansion. Several of the CPU coolers I have investigated seem to have a problem with encroaching on the RAM slots space, so I probably would need the standard height modules rather than the ones with cooling fins. I don't plan to try overclocking the RAM. The Gigabyte memory compatibility list shows very few 8GB 1600 module choices. Is compatibility an issue?
Monitor: I'm open to suggestions.
Do you plan on overclocking? If yes, do you have a specific goal in mind?
Moderate overclocking. No specific goal.
Would you prefer the build to be particularly small?
Mid-tower is OK.
Would you prefer the build to be particularly quiet?
Yes.
In general, do you prefer this to be a computer that you can spend money on now and let it rest, or a box built for continuous upgrading?
Prefer to build a system that will be adequate for several years but with ability to add additional RAM or hard drives as needed.
Do you ever plan on utilizing NVIDIA's SLI or AMD's CrossfireX technologies? These features, with a compatible motherboard, allow a user to link multiple identical graphic cards together for added performance. In real world terms, this lets you buy a second identical graphics card down the line as a relatively cheap and easy way to gain a fairly large boost in performance. However, this requires buying a SLI/CFX compatible motherboard and PSU now, which may result in slightly higher initial cost.
Probably will use only 1 GPU.
CPU: Intel i7-3770K
About $2000
Yes
Yes
Mid-tower is OK.
Yes.
