- Feb 7, 2013
Hey,
after a lot of consideration and thoughts I came to the conclusion that I want to water cool my current system. Although the drops in temperatures (except for the GPU maybe) do not justify a custom WC setup, I like the idea of building / customizing it. It's a hobby as someone pointed out in an older thread of me.
So, what do I want to know and what do I already know? A friend of mine has build several WC systems and therefore will assist me building my new rig. We decided that we wanted to go with a complete custom case, he was so kind to render our rough draft in C4D.
What parts do we plan to use?
Alphacool HF 14 Smart Motion Universal Copper Edition
Alphacool MCX 5x Verteiler G1/4
Alphacool MCX ram
Anschlusskit Verschraubung 13/10mm G1/4" gemischt
Aquacomputer Aquastream XT USB 12V Pumpe- Standard Version
Aquacomputer cuplex kryos Delrin für Sockel 1366/1156/1155/775, G1/4"
Masterkleer Schlauch PVC 12,7/9,5mm (3/8"ID) Clear 3,3m (10ft) "Retail Package"
Phobya Balancer 250 black nickel
Phobya Xtreme NOVA 1080 Radiator - Full Copper
Scythe Glide Stream 140 SY1425HB12L 800rpm ( 140x140x25mm )
Tygon R3607 Schlauch 5/3mm klar
I would like to have some input / feedback of what parts we could/should change.
We have to go for that custom GPU solution since my 580 is non ref design and you can't get any fitting waterblocks for it.
I know the nova 1080 is huge, and I might could go with 1 or 2 smaller rads, but it fits our design idea and should allow me to go completely passive in idle (at least my friend can with his mo-ra 2). 3 fans for load (I might change the enclosure of the radiator and add additional 3 fans on the top, outside the case).
So far I came up with:
CPU TDP 95W
GPU TDP 165W
260W
Assuming using 3(6) instead of 9 fans would change the C/W by the factor 2(1.5), since I think the massive size of the radiator accounts for more than the fans. Values taken from http://www.dexgo.com/
3 fans total|400 RPM|600RPM|1200RPM
R_th[K/W]|0.067|0.047|0.025
dT|17.42K|12.22K|6.5K
6 fans total|400 RPM|600RPM|1200RPM
R_th[K/W]|0.05025|0.03525|0.01875
dT|13.07K|9.17K|4.88K
Assuming 260W is not the exact heat load + my R_th are calculated a bit bigger than they really are I think this setup should allow for good overclocking options.
I think we would start building / ordering in June or Juli. Have to save up some extra cash first, since the parts for the case could be hard to get / pricy in sum and I don't like surprises on that field. Just so you know, in case there are better / newer parts announced for that time.
This part has nothing to do with the WC itself, just so you know. The theme of the build will be steampunk and Im thinking of a purple or blue/red-ish LED setup, if you have any creative input
Then, thanks in advance and I look forward to be enlighted
Alphacool MCX ram
CPU TDP 95W
GPU TDP 165W
260W
