After years of wanting to get into water cooling and using AIO kits I finally bought a kit and going to dive into things.
I ordered the XSPC Raystorm EX240 kit from Performance PCS, I opted out from buying the $16 coolant they had and wanted to ask a few questions before I got some coolant. Since coolant is just distilled water with PH Nuke added, if I go buy a gallon of distilled water from wal-mart and pick up some $5 PH Nuke off amazon that should be good enough for my system shouldn't it? Also, if I want to dye the water, what do most companies use? Food coloring? or would that stain the inside of the system?
