- Dec 15, 2010
- Bowling Green, KY
I have lurked in this and forums like it for a few years ... and have finally just received my order from newegg and will be putting my system together this week ...
I want to eventually watercool for what i perceive would be even quieter operation but figure i better build an air cooled rig first since its my first build then modify it to watercooling later if i need.
This may be long but I want to lay out what my goals are and receive some help in accomplishing them...
Goals: HIGH END DEAD QUIET GAMING RIG and bought highest end parts i could find ( i bought the case in 2008 but never ordered any othe rparts ) so i could get away without overclocker and pick up as much silence as possible... and have a preference for as many blue led fans as i can use if not all slots
Parts:
CPU: i7 980x Extreme Edition
CPU cooler: V8 cooler master
MOBO: Asus P6X58D Premium
RAM: DDR3 1600 mghz Crucial Balistix blue led Tracers 12 GB 6x2
GPU: PowerColor AX6970 2GBD5
SSD: OCZ IBIS 240GB HSDL (High Sp Data Link)
PSU: KINGWIN LZG GOLD 1000W
CHASIS: Silverstone TJ09
OS: Microsoft Windows 7 Professional 64-bit
All my parts are in from newegg and I am ready to begin build with one exception: Fans and Fan control except the rear and midsection stock fan that came with case ...
here is a picture of the case I own not mine just a stock pic ...
here are the fan specs for my case:
Front 1 x 120mm fan slot between HDD cages
Rear 1 x 120mm exhaust fan, 1200rpm, 21dBA
Side 1 x 120mm mid-section fan, 1200rpm, 21dBA ( which pulls in ambient air from the sides of the system with two hot rod scoop like entry points
Top 2 x 120mm fan slots
SO qustions i have:
1.) will 5x of these in my 5 slots create enough air flow without overclocking to cool everything?
YATE LOON blue LEDS ( there are three models though ... seems to be a high medium and low speed but not sure? if that is the case can i get away with lowest quietest ? and keep everything cool without overclocking? )
http://www.frozencpu.com/products/6...Fan_-_UV_Blue_D12SM-124UB.html?tl=g36c331s518
2.) might I also place one of these fans in the coolermaster V8 CPU cooler to get rid of the red one that is in it now?
3.) i realize even if i can do all of the above that the VGA card fan is still going to be loud at load ... on this new 6970 i bought is there a quieter non stock air cooling mod i can do like some sort of big air cooler with quieter fan ... those things being shoved in those cases with those small fans do not seem very efficient for cooling ...
if there is not do they make a system like an h50 for Video cards instead of CPU's becuase i do not think my cpu will be the problem in seeking silence as much as possible ... i think the kink will be the VGA card even if you guys think i can do the rest of the above..
4.) what sort of fan control if any would you recommend... i was leaning towards this one just becuase it goes with them of case
http://www.frozencpu.com/products/7...troller_-_Silver_RHK-EX-SV.html?tl=g47c17s239
Well i know it was long but i really thank anyone who can give me some thoughts on building this rig the way i envision it ...
once i have my fan decisions made ill post a build log for you guys to watch i newbie go at it heh ... i did paint my case a really nice clearcoat finished racing blue mustang color ... ill show some pics in a log before i get started
then ill post a pic at some point when my new monitors come in of my MMO multiboxing setup
should like that that ... as long as my terrible computing skills dont keep me down like this and building the rig doesnt make me feel like
thanks again
ryan
Parts:
SO qustions i have:
thanks again
ryan
