That is the burning question for me and i'm sure a lot of others
So how does the 2 Module Piledriver compare to Bulldozer and the i3.
I have pulled together some reviews which might answer that.
If we pull up AnandBench to compare it with Phenom II;
The 3.8Ghz 2M 4C Piledriver is on a Parr with the 3.4Ghz 4C 965 BE.
sadly AnandBench don't have the Bulldozer FX-4 listed.
So from other reviews;
In this one and this one it's consistently behind the Intel i3, but consistently ahead of the higher clocked FX-4170
in This one it seems to be on a parr with the Intel i3.
Tom's Hardware also have it stacking up against the i3 very well.
What i would like to take away from that is the Piledriver core is a definite improvement over Bulldozer, it would have to be to beat a higher clocked Bulldozer with the same number of module and cores while also not having L3 cache.
Depending on whose review your looking at, and what they chose to use to benchmark it; it can be slower, faster or on a parr with the i3.
More often than not in real life apps it is a match for it, or it beats it.
I think the 2 Module AMD has caught up with the 2 core Intel.
The question for me is is the coming FX-8350 an upgrade path from my trusty old 1090T which is getting very long in the tooth.
I know Trinity is not Vishera, but it is Piledriver, as is Vishera.
Based on this information, nothing stands out, other than it definitely is better than Bulldozer, and reviewers have been able to overclock it ranging from 4.4Ghz to 4.6Ghz (on the stock cooler) which is good.
For me they are still on my list, but not underlined.
