I really don't care what you think, or what your getting at. I don't need to prove anything to you! I know what I can do and what I have! Sorry I don't Prime again for 7 more hours. I have a job and family with kids that I have to tend to, and when I have time I spend it very efficiently with my PCs. So setting up my other water cooling system and running Prime95 for 7 more hours just to get you off my back is a big waste of my time since I don't have much time in the first place.
I don't believe you know what your talking about, you will have to prove it... now how about you prove it to me! To me your just some dude on the internet who thinks he knows what he is talking about...see how I can play this game too! No matter what you say to me I wont believe you either, so I think this conversation is done now. BYE
Sir, I talk to people every day that buy tens, twenties and thirty of these chips to overclock simply so they can find the best.
I've started a thread at XtremeSystems.org for our members there to add their information and highest overclocks, as well as temperatures and more, all so we can find the average clocks of the platform as well as what is normal for higher and lower than average.
You outreach higher than average by about 250 MHz, at a voltage used for average chips at 50-100 MHz under the average clock achieved.
Over twenty people replied to that thread, several of which are the people that buy 5,10,15,20 of the CPU at a time to find the best to overclock on liquid nitrogen cooling and achieve world records.
While I do not have such deep pockets as some of my friends, I'm definitely not an idiot.
No, it wouldn't reach the same overclock with LLC off on that board. That's why I said it was a band-aid to patch the problem, not a fix. They never fixed the larger problem in the first place - that their power section was incapable of keeping voltage constant. Instead they introduced the controller that had LLC and left the actual power delivery the same. The LLC chip controls voltage much better than the board does by default, allowing people to use it to smooth out the voltage output.
LLC should be there to control Vdroop (or eliminate it), it should not be there to fix a problem of voltage output fluctuating dramatically.
This statement has caused more trouble in this thread than it was designed to fix.
vdroop is not a problem, vdroop is a safety measure. When a VRM output voltage droops under load, (within a tolerance, of course) it is doing what it was designed to do. When we set up the VRM to offset this vdroop when there is more current draw, ...
(by adding/removing resistors or using a variable resistor to alter a circuit, or making a circuit with different paths, which is physical, but the path changes when you enable/disable LLC in software which sets the controller)...you introduce something else into the behavior of the circuit, a transient overshoot, which is a small burst of higher-than-normal voltage when the load is first applied, which can go outside normal component working specifications.
Lets use caddi_daddi's quest for 4.5 GHz on his 955 BE for example.
He needed 1.644v in CPU-Z at load (and lower temps, but leave that out) to reach 4.5 GHz in Prime95 for 2 hours.
Without LLC enabled on a high setting on his board, his idle voltage would have needed to be about 1.775v.
See the problem (and idiocy) here ?
Well, when he enabled LLC, and set it to "Ultra High" or "Extreme" like he did, he only needed an idle voltage of about 1.62v, making it a bit safer.
However, for a split second, maybe even 1/250th of a second, when he applied a 100% load to his CPU, chances are, that his voltage spiked unmeasureably upwards of 1.8v.
See the problem here, too?
If you anyone is having trouble understanding why, then there is a good read here:
http://www.thetechrepository.com/showthread.php?t=126
