Well, I know that Vdroop enabled prevents voltage from sagging upon load. You can reach the same clocks without it by just adding vcore. LLC does not have anything to do with reaching the 'true value' of a chip AFAIK.
For example say 4.5Ghz 1.45v load is stable and you have .03 vdroop on load. You can:
1. Set bios to 1.48v with NO LLC and it will droop to your load voltage.
2. Set bios to 1.45v with LLC and it will stay at 1.45v.
6 of one, half dozen of the other there at the same clocks... doesnt matter what clockspeed though.
The point is LLC doesnt unleash anything but more stable voltages upon load. I don't imagine this to be different on BD as it was on all Intel chips I have overclocked. This is the first time I heard of it increasing potential of a CPU and I'm having trouble believing it I must admit (because that isnt true truth be told).
But not having LLC and setting the cpu volt to 1.6v to achieve 5.0+ghz oc on the BD for 10 min is dumb and very unstable, or can set LLC and have 1.46v and have 5.0+ ghz STABLE ...you save money, have less heat and get better OC's too. I am sorry keeping the FX8120 stable at 5.0ghz gets pretty awesome results. AM3+ MoBo without LLC good luck keeping BD stable at 4.6ghz
Term stable= not crashing under load, running Prime without errors for 7+hours, not 5 min.
